Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
Which one?
by RogerBacon
02/25/18 12:25 PM
VW Polo, 1.4 TSI 150hp (ea211) 0w-30. 11700km
by VTS16
02/25/18 12:16 PM
Atlanta Quick Trip 500
by bdcardinal
02/25/18 11:58 AM
Gumout One N Done vs All In One
by Patman
02/25/18 11:44 AM
ACEA A5/B5 vs ACEA A3/B4 for Volvo V60 Polestar?
by A1ex
02/25/18 11:36 AM
Vogue Signature V tire review
by 2strokeNorthstar
02/25/18 11:33 AM
Which have improved faster - engines or oils?
by HawkeyeScott
02/25/18 11:12 AM
PP 5W20 bottom of jug debris
by aquariuscsm
02/25/18 11:05 AM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
98 registered (andrewp1998, 2015_PSD, A1ex, 08versa, ammolab, 93cruiser, 6 invisible), 1860 Guests and 91 Spiders online.
64288 Members
65 Forums
278790 Topics
Page 1 of 3 1 2 3 >
#4107682 - 05/26/16 11:31 PM Undercarriage Rust Management
OpenClose Offline
Loc: Indiana
Hey guys.
So my Buick Regal is now "salvage" after a moderate bump by a truck slightly buckled a quarter-panel. So naturally, I kept the car, since like half the purpose of this (my first) car has been to DIY what I can and learn how to do things myself and when to know when to leave it to the pros.
So as much as I have been under my car, I've noticed it is fairly rusty. I thought this was a fairly normal thing, but apparently it is something that needs to be tackled. The original muffler exploded during the test drive, apparently due to rust. So I replaced that right away with a larger pipe and Magnaflow. The brake line also broke from rust, so my dad and I worked on replacing the whole line (it works very well now!). The drive axles are fairly rusty, though mostly surface.
So what products and methods do you guys recommend for cleaning rust and sealing FROM rust? I've seen where people just spray some rustoleum on the rusty parts, but I figured there would be more to it than that. A good cleaning at the very least.
1999 Buick Regal GS SC 115k
Pennzoil Platinum w/ PurePlus
FRAM Ultra Synthetic
TransGo Shift Kit
#4107689 - 05/27/16 12:01 AM Re: Undercarriage Rust Management [Re: OpenClose]
buck91 Offline
Loc: West Michigan
Some options:
POR15
Wire wheel or sandblast, prime and paint
oil spray
Krown
Fluid Film
I like fluid film as it very easy to apply and pretty effective- not perfect though.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4107706 - 05/27/16 12:27 AM Re: Undercarriage Rust Management [Re: OpenClose]
Need4racin Offline
Loc: US
pressure wash it every spring to remove the salt and brine. Use garden hose to get in the pockets too. Then paint it with black spray paint...careful of overspray and your eyes, hands, nose.
#4107709 - 05/27/16 12:30 AM Re: Undercarriage Rust Management [Re: buck91]
turtlevette Offline
Loc: Massachusetts
Paint what you can right over the rust, then spray your used oil with a garden sprayer thereafter. I'm not convinced the quality of the paint matters that much. 2 dollar rattle can primer adheres just as long as POR.
Cut your used motor oil with diesel to make it more sprayable. I'm trying to work out putting a 90 degree fitting on my garden sprayer wand so I can just pass it under the car without jacking.
Bottom line. Oil the heck out of it. Areas of my 40 year old cars that look perfect are where there was a steady drip from the engine and tranny. If my trans am hadnt had a wicked leaky rear tranny seal, it would be beer cans by now.
USA-1
#4107768 - 05/27/16 06:24 AM Re: Undercarriage Rust Management [Re: OpenClose]
Olas Offline
Loc: Manchester, England
If you already have a way of getting the car in the air, then all you'll need is a drill with a wire brush attatchment to get down to bare metal.
One you can see bare metall, paint generously with Waxoyl. It will NOT rust after you do that..
Cable ties should hold it
#4107769 - 05/27/16 06:25 AM Re: Undercarriage Rust Management [Re: OpenClose]
larryinnewyork Offline
Loc: One Step Beyond
When I started driving/maintaining my own vehicle in the 70's, it was standard to let them rust and then complain about it.
It does not have to be that way.
My 2002/134,000 miles Ford Ranger has no rust yet.
My solution has been to get the underside sprayed with an undercoating oil.
Suggestions:
1) Have it done professionally the first time (check Yellow Pages and ask around).
They will spray in the doors, hood, trunk, brake & gas lines etc.
This will cost around $100.00 and will be the most effective and time saving way to go.
The oil will penetrate the rust and work its way to the base metal resulting in no further rusting. The oil will also work its way around the spot welds and in seams.
2) Buy Fluid Film in Aerosol cans and a 1 gallon can and use it for touch up work in the Fall.
I buy Fluid Film (aerosol) from E-Bay sellers (12 cans/1 case).
The 1 gallon can lasts along time.
3) Any future vehicle you own, get it oil sprayed right away and you may never have rust problems again.
4) Right or wrong, I've been coating my brake lines with Never-Seize (aluminum) and to this day, if I wipe it off, the brake lines look brand new.
I wish someone explained all this to me years ago instead of learning the hard way.
Good luck.
DO NOT BE TEMPTED TO USE MOTOR OIL FOR UNDERCOATING. IT'S THE WRONG CHOICE IN MANY WAYS
Edit: Fluid Film will not harm any rubber components, or electrical wiring, used motor oil will.
Fluid Film is Lanolin base (oil from sheep wool).
Edited by larryinnewyork (05/27/16 06:29 AM)
#4107771 - 05/27/16 06:28 AM Re: Undercarriage Rust Management [Re: OpenClose]
Donald Offline
Loc: Upstate NY
I would suggest Krown or Carwell. Either of those will penetrate the rust and block future rust. Wire brushing/sanding and then prime and paint is fine for easy to access flat areas, but the undercarriage of a vehicle has many areas that will not be easy to wire brush/sand.
You can order CSarWell by the gallon. It can be sprayed or brushed on.
FluidFilm is similar to CarWell, but does not last quite as long.
Don't forget to look at the pinch seams of the doors for rust.
2015 Ford F250 w/Powerstroke
#4107785 - 05/27/16 06:56 AM Re: Undercarriage Rust Management [Re: larryinnewyork]
Donald Offline
Loc: Upstate NY
Suggestions:
Good luck.
I agree, get it done by a shop the first time (watch) and don't use used motor oil as the product.
#4107878 - 05/27/16 09:00 AM Re: Undercarriage Rust Management [Re: turtlevette]
Donald Offline
Loc: Upstate NY
People should be properly disposing of used motor oil not spraying it on the undercarriage of their vehicle. Imagine what a mess our environment would be if when you went to Jiffy Lube, then changed your oil and filter and then sprayed the used motor oil on your vehicle's undercarriage and you drove off dripping motor oil all over for the next 500 miles.
#4107898 - 05/27/16 09:32 AM Re: Undercarriage Rust Management [Re: OpenClose]
Ducked Offline
Loc: Taiwan
Used motor oil is teratogenic and carcinogenic.
Unused motor oil isn't, and a little goes a very long way.
I use a blend of motor oil, diesel and sunflower oil. Fluid Film MAY be much better but you can't get it here.
I've used Waxoyl (which is probably similar, and which you can't get here either) a LONG time ago and didn't think much of it.
In context its quite important that you use something that's easy (and preferably cheap) to use, else you wont use it.
#4107911 - 05/27/16 09:47 AM Re: Undercarriage Rust Management [Re: Ducked]
turtlevette Offline
Loc: Massachusetts
Its not on your skin. Its under the car. Exhaust is extremely deadly, but your face is not 6" from the exhaust. The asphalt roads are very toxic too. Brake dust is toxic. Rubber particles cause cancer. People think a few drops of oil is so horrible.
Motor oil does stink though. Use your used frying oil instead.
USA-1
#4107939 - 05/27/16 10:17 AM Re: Undercarriage Rust Management [Re: Need4racin]
Noey Offline
Loc: Ct., USA
^Do not do this.
Pressure washing on an intact (i.e. non rusty) vehicle will result in you blowing off all the anti rust coatings that protect the underside. Use a garden hose, you do not need 1500ft/lb of pressure to wash away salt.
In a car as old and deteriorated as yours, if there's no structural rust...look around the joints where suspension parts meet the under body...then a one step rust block/sealer is your best bet. Get under other with a stiff metal brush to remove as much rust as possible.
But like most advanced cancers, once rust takes a firm hold on your car, the goal is palliative rather than restorative.
"I don't know nothin' 'bout birthin' babies!"
#4107957 - 05/27/16 10:38 AM Re: Undercarriage Rust Management [Re: OpenClose]
sr17 Offline
Loc: Vancouver, BC
Corrosion X is another amazing product - I use both the thin penetrating version and the thick and sticky undercoating version - effective, even on my boat trailer springs that get dunked in salt water regularly.
2005 VW Jetta TDI - 222,000 km, M1 TDT
2000 VW Golf TDI - 354,000 km, Shell T6
1991 GMC Sierra 2500 5.7L 4 WD
#4107971 - 05/27/16 10:54 AM Re: Undercarriage Rust Management [Re: Noey]
LeakySeals Offline
Loc: Hudson, NH
^Do not do this.
Would think that pressure would be bad for any wire harness. Also would a clean undercarriage be more likely to rust because there is a better supply of oxygen to exposed or rusting metal?
06 Escalade 6.0L AWD 155k. M1 EP 5w30 Fram TG
03 Maxima 3.5L Unknown miles ST 10w30
#4108086 - 05/27/16 12:42 PM Re: Undercarriage Rust Management [Re: OpenClose]
Hey guys.
This sounds like something a Father would say.
Once I found this web-site, I take better care of my vehicle.
I change ALL the fluids, which has to go a long way in 'preventive' maintenance.
Small to medium Repairs - Get advise here from others. Even if it's just to confirm your common sense.
You-Tube is also very good.
And about the oil-undercoating: I'm always wiping the oil off the doors and tailgate because it 'creeps'. That's what you want in an undercoating oil.
Page 1 of 3 1 2 3 >
