Hood Latch Grease?
Indiana
Anyone have any recommendations for a quality hood latch grease? I'm sure WD40 would help, but I'd rather have a more permanent fix.
Thanks guys.
White lithium grease, LPS 2, Amsoil MPHD, Schaeffer Penetro, whatever spray lube I've got nearby that will stick around longer than 3-in-1 oil.
I've been using the Amsoil Heavy Duty Metal Protector on door hinges and hood latches and I'm happy with the results. It dries leaving a wax like film that doesn't attract dirt like white grease.
Originally Posted By: dlundblad
I just went with some spray lithium grease I already had on hand. Thanks guys.
I had a similar problem, but no spray Lithium grease. I was about to buy some, but decided to give some motorcycle chain spray lube a try. It worked fine.
I sometimes use aerosol white lithium grease, but I prefer Super Lube Aerosol with PTFE. I have a can that was packaged for AC Delco.
