Toro 120-4276 Oil Filter Cross Ref?
MD
I looked this up and find nothing.
This is for the Toro-Exmark Zero turn 708 cc engine.
Anybody using a better oil filter or an easier to source one.
I came up with zero..
Thanks!
Thank you 901- You really went overboard!!!
I just found a NIB older Catrol MaxPro Plus 3614
They say KMart sold these once long ago- I'll check to see if it matches up to fram 3614.
I do have 3" of clearance from the 120-4276
I'd probably use the Fram Ultra XG 3600 if it fits. They are huge and boost the overall oil capacity a smidgen. You can run them for double the manufacturers hour interval easy.
Yes they do look good and I'm a fan of the XG's
I'll give it a shot.
What's on there is really dinky... THANKS!
For any filter cross info, try the Fram site.
It has a really good cross-matching tool.
It came up with nothing for the Toro number but Wix did and then
I took that info back to Fram.
