Originally Posted By: HemiHawk
Thanks for the info! I wonder what this N20 test is?? Does it have anything to do with the start/stop function of the motor?
I also wonder if other brands have not needed to remove the LL-01 cert because they havent re-formulated. Meaning the new 0w40 FS is "new" so it had to be retested?
For the N20 performance test, it evaluates Piston cleanliness, engine cleanliness, oil aging and protection against wear by running the oil through a series of engine sequences in a BMW N20 engine.
They run the oil through a series of engine cycles, topping up the engine with new oil as needed, then partway through they change the oil and then run several more cycles with no extra top up. At the end of the test they look at overal engine cleanliness (oil pan, heat exchanger, cylinder head, cylinder head cover, pistons, rings, the turbocharger and an oil analysis) to see how well the oil stood up under service.
