Originally Posted By: tomcat27
I'm upgrading the ignition points in my car to electronic. any real advantage to an MSD system over a Pertronix style? (other than to drain your wallet) and, with the MSD, I don't see a real advantage to their separate CDI box (like the 6AL) over a new MSD Billet distributor with the built in module. the MSD system costs $500 either way (separate pieces vs all-in-one); the Pertronix is $100 plus the cost of rebuilding my distributor...
I know a lot of people that are happy with Pertronix, but I worry about electronics in the hot, ozone-filled, harsh environment under a distributor cap. The MSD remote box is big, well-cooled, and can be isolated from EMI sources. I'm hoping mine lasts a long, long time.
FWIW, I was not expecting to notice any performance improvement when I installed an MSD6AL on my '66 Polara. It had already been converted to Mopar factory electronic ignition (70s vintage), and I'd also used GM HEI triggered from the Mopar distributor. Those worked OK, but both are only available aftermarket these days and quality of the parts really seems to be slipping- the last few HEI modules I had only lasted a few years each. But it actually does run (especially idle and at throttle tip-in) noticeably better with the 6AL. The whole multi-spark thing really does have some benefit after all, at least with carbureted engines and moderate-to-big cams. I'm using a stock Chrysler distributor with the electronic reluctor pickup that Chrysler systems use (MSD is compatible with it), and a stock coil. MSD will also use points to trigger it just fine, and points will last essentially forever when they don't have to carry the full current of the coil. The box is the only thing that really has to be bought, unless your distributor is too far gone to use without a big overhaul, or you want the added timing stability of an electronic pickup. The MSD box also has a tach output ready to go, and a shut-down lead that you can hook to a hidden kill switch for security if you want. Its a pretty nice setup, and while expensive I don't think its extreme overkill.
