I will share this I read from a brochure.
Lubricating Oil Analysis - Warning Values
A fuel dilution exceeding 7.1% by volume indicates an immediate need for an oil change and corrective maintenance action. Fuel dilution can be confirmed by ASTM D3524 test procedure performed by oil suppliers or independent laboratories.
In addition to the above considerations, the oil drain interval for Detroit Engines has been exceeded if:
*The viscosity at 212F (100C) of a used oil sample exceeds 21.9 cst (15w-40).
*The iron content is greater than 200 parts per million.
*The carbon (soot) content by TGA exceeds 4.5% by weight (ASTM E1131).
*The total base number (TBN) is less than 33% of original (ASTM D4739).
