Awesome numbers. It amazes me when see great numbers with low saps oils. I haven't done oil analysis on my tdi 2011 golf and generally do not run oil past 7500 miles; but have used low saps oils throughout and vehicle has 207000 miles on it. I have never added makeup oil either. I did have dpf replaced under warranty at 72000 miles. The engine light comes on now and reads as poor egr flow. Took it to local shop and would likely have to replace dpf again-but am waiting for the VW fix as car runs fine with same mileage get solid 38-39 miles per gallon. The weird thing about the engine light is it never comes on when weather is cold under forty degrees. However it comes on usually within a mile of first starting or when restart car when weather is 50 or above.
