Originally Posted By: SrDriver
I had one called a "CAT" card (Common Access Card) like you mentioned while working. When I retired turned it in.
Had everything you mentioned but not sure about DNA code?
the "Real Id Act", social security card, etc. Cell Phones, etc., all provide a wealth of information.
CAC, not "'CAT' card".
CAC's can hold a lot of information, but they're typically used to store PKI (Public Key Infrastructure) information, allowing access to systems, the ability to encrypt/decrypt systems, etc.
At least with military and civilian CAC's and tokens that I've experienced, there isn't any implemented biometrics, at least at my level of clearance. Mine simply holds my name, title, and PKI. I choose which cert to use and apply the associated PIN. The card, by itself, mostly is worthless. A lot of outward Personally Identifiable Information (e.g., ssn) has been removed from most CAC's, listing only ID (e.g., DOD ID) numbers.
Please don't read the above as refuting implementation, current or future, of biometrics; I'm simply stating my limited experience with mil and civ.
With all of that above out of the way, I have no problem (probably due to the nature of my jobs) having almost everything about me on file. I enjoy quick and easy travel, access to some cool stuff, and other perks.
Most people don't travel and don't need a high level of scrutiny for normal every-day purposes, so I can understand being alarmed at any attempt to gather bulk information on many people who are not a threat and don't interact with anything requiring their information to be gathered or stored.
The major concern that I continue to have, is when the secured, encrypted databases are breached, and all of that "protected" information is spread out across the world, to be used by the highest nefarious bidder(s). I've not experienced any negative side effects of the various low and high-level breaches in the past (e.g., Target breach), but that just means my risk percentage rises each time, right?
Originally Posted By: Doog
Originally Posted By: gathermewool
Not even going to. I'll just sit here and
read up dude....it's already being done.
https://www.fbi.gov/foia/privacy-impact-assessments/iafis-ngi-risc
My post was based on what I suspected the response from this forum would be, not the validity/likelihood/etc of your post.
