Originally Posted By: RusskiBoSS
Originally Posted By: Astro14
Where is your city? Which one do you live in?
How do you know the same airplanes are flying back and forth, and not just different airplanes on airways? Did you visually identify them by type? It's pretty hard to read the registration number from the ground.
And you're certain that a persistent trail has a chemical composition?
It couldn't possibly be due to the rate of evaporation based on the relative humidity of the air at that altitude on that day?
After 29 years of flying, I'm still looking for the chemtrail nozzles...and haven't found them.
So, what airplanes are doing the spraying? Who owns them? Who flies them?
North Carolina is my state. I am in aviation Field as well (Avionics). One thing I tell you is - just because YOU have not seen it, does not mean it does not exist. Those chemtrails show up overnight and clear up by noon. Even if I wanted to - I wouldn't be able to see the N-numbers on those jets at night. You hit a dead end and now going to "Asking for proof" method because you know that what I am saying is true, and you're just trying to come up with anything to come out as a winner. I am sorry, but that's just childish.
It's childish to ask you to defend the specific points of your argument?
I'm not seeking to "win", but I am seeking to understand how you could believe something so ridiculous. Chemtrails are tinfoil hat, conspiracy theory, garbage, plain and simple.
You claim it's widespread and has an effect.
But you've never seen the equipment, or met anyone that has worked on it?
I asked for your location so that I could post the jetways above you...you might be surprised at what is actually going on above you.
In the meantime, I've seen lots of contrails, but I have yet to see a chemtrail.
I still don't understand how you can look up 35,000 feet and determine the aircraft type and chemical composition of the contrail.
After all, they can't be commercial airplanes, or you and I would have seen the equipment, right? And the contrails are there on most every flight, it's the nature of hot exhaust containing water vapor hitting -60 degree air...so how do you determine which trails are chemtrails?
