Originally Posted By: Shannow
Originally Posted By: MotoTribologist
The 10W-50 should burn less oil. Its thermal stability should be better than a 15W-40 and it being an SAE 50 should prevent more exchange between the crank and the cylinder than an SAE 40 would, thereby limiting the amount of oil getting into the combustion chamber.
Not sure what you mean by thermal stability, but the 10W50 will probably have the lighter basestock, more VII additives, lower flashpoint, ad s Joe90_guy points out higher NOACK.
10W50 would have an HTHS around 4.8 (for a synth) versus 4.3-4.4 for a dino 15W40, and that gap is likely to close in service.
I'd take the cheaper 15W40 over the 10W50...or as OP has suggested, just use the same oil in both cars, 20W50.
By thermal stability I basically mean VI, since the change in viscosity over the temperature range should be less than a 15W-40 in most cases.
Those other properties you pointed out are generalities though and are not necessarily accurate for all brands. Volatility in particular can change drastically from one brand to another within the same vis range. If they rely solely on VI improver to build viscosity rather than base stock adjustment, then yes the volatility will be high, but if a high vis base fluid is used instead, then the volatility should decrease in general.
Since the only known difference in properties between the two grades are the viscosity at low and high temperature, the thicker 50 weight should provide a stronger (or at least thicker) oil film to resist blow-by and oil being forced into the chamber. Since the OP only asked about the difference between 15W-40 and 10W-50, those are all I commented on, but yeah a cheap 20W-50 will probably be better still and not break the bank. I just didn't want to expand on the original options laid out.
EDIT: When I say drastic I of course mean that in a relative sense since NOACK is a pretty tight spec to begin with, so you may have one at 5% and another at 9% for instance which I would consider "drastic" although in the grand scheme it isn't that big of a difference
