Originally Posted By: GatorJ
Originally Posted By: Clevy
Originally Posted By: HAWG4LIFE
I know the regular oil stabilizer is junk, but is this any better?
No.
What part of an oil formulated today is unstable and requires something so thick,and non-additized to compensate.
Try running non-additized oil is an engine and time its life with a stopwatch.
LOL. Or requires Liqui-Moly? Quick answer? None.
Really.
I've cured gasket leaks with liqui-moly motor oil saver and gained mileage using mos2.
So do tell genius,considering they are additized,and actually do something how exactly do they compare to a non-additized,molasses thick additive.
If you can show me the exact same benefits just using a standard motor as I've experienced using liqui-moly then by golly I'll quit buying the stuff,til then how about sticking to the topic.
