Originally Posted By: dgunay
I've been tuning my cars for a very long time (current car has more than 20 different maps including variable timing for each 10 degrees), and I am 100% sure that properly adjusted fuel trims (means less than +-3% for me) helps to smoothen the ride and throttle response. The more it is properly adjusted, the less primary 02 + ECU have to manipulate the a/f ratio in order to reach stoichiometric efficiency (14.7) in the closed loop.
I am not saying they only changed the fuel trims, but it's the #1 factor that smoothens the ride when it's in the closed loop.
I forgot to add (no edit)
......and the less ECU manipulates the a/f ratio based on primary o2 readings (which means closer to 0), the smoother ride you get. So our aim is to prevent fuel trim spikes in order to get the best results when tuning a car(especially if it's daily driven).
So what I am trying to say is, adjusting fuel trims are not that "simple" as you mentioned. Even though ECU compensates the fuel trims, it isn't properly adjusted and there will be fuel trim spikes. Fuel trim spikes make your car run [censored].
If you search google, you'd find tons of rough idle/acceleration problems due to unadjusted fuel trims.
I think we're on the same page, just using different terminology. It sounds like you're saying that you tune your fuel mapping, not your fuel trim. In my experience, fuel trims ARE what the ECM adds or subtracts based on O2 sensor (primary only or mostly primary and some secondary.)
In other words, the MAF scaling and ECM fuel tables constitute the base fueling, with compensation provided by the fuel trim, which is 100% dynamic and NOT able to be tuned.
