hello man..
does ur car use 2kd-ftv engine? that's D4D..
i suggest you use multigrade oil whic is maybe minimal using 15w-40 such as mobil delvac mx, thats common oil..
mine using Q8 T800 10w40, thats HDEO oil that could run 10000 km since high sulfur contain diesel fuel in my place..
using single grade SAE 40, it will consume the fuel consumption in the first time u start the engine. the pump will need extra work to pump up the oil through the engine.
