Originally Posted By: cb_13
The Snap On guy took them in as trade and the guys paid the difference for Snap On impacts.
I wasn't questioning your honesty but i sure am the SO guys. The OP has a SO gun that pizzes oil whats with that failure?
Any tool can fail air or otherwise, they need maintenance. If they were not greased, lubed properly daily or the compressor has no water filter they can fail quickly regardless or make.
I see this all the time, the IR fan s claim Aircats are no good but when asked if they ever owned one the answer is no, same for Snap On but they all heard it so they post it on some forum.
You can see the reaction in some of the threads, "if the IR buttons fall out i will just replace the case", I will get the leaking Snap On repaired because they are better guns. WTH is that, if that was a cat they would be calling it fit to burn.
The fact is none of the guns are the same quality and the commercial units but for $160 on the door the Aircat with its 2 year warranty make a compelling case for itself.
