I went to the parts store and got the fuel pump they had listed for a 1970 ford 428 engine and it looked like this:
Pump that came off the truck, and ones that I see listed for FE engines looked like this:
I put the pump on the truck and it is working fine no leaks or funny noises. Anyone see any problem running the pump with the straight pump arm instead of the more curved one that was on the engine? Other than the angle of the pump arm they looked identical. From what I've been seeing the straight arm pump came on 429/460 engines.
