My sc2500a showed no Dc output voltage plugged into 120vAC, and pressing buttons did nothing to change this.
If I pulled a cable when charging, and tried to measure DC voltage, nothing.
If I set the DMM to auto range I was able to read 18 Millivolts, but the leads in my hands I was able to read 65 or more. But in the 20 range, 00.00v.
After this, I used it on the 12 amp AGM setting to charge an old abused flooded group31 "deep cycle" battery. It went upto 14.89 volts then dropped to 13.61 after a period of time.
I then plugged in my Meanwell power supply and the battery took another 8AH at 14.7v before amps into battery tapered to under 1.5. I did not bother with the hydrometer, I knew the schumacher quit absorption voltage early, I knew I could stuff more juice into it with my MeanWell power supply at 14.7v, as I always can.
I know one cell on this battery will never go higher than 1.250 when the other five likely still can be brought upto 1.275
