I visit this site occasionally since I consider it the premium oil site on the web. I have a 94 Bronco and a 06 PSD 6liter.
I usually run Mobil one 5w40 diesel oil in both vehicles. This winter I got lazy and have run M1 15w50 in the 5.8 Bronco. I let it warm up on cold days and notice no difference in the sound of the engine. I've had this truck for over 21 years now and have only used M1 oils, and from 5w30 to 15w50. No leaks, no tappet noise, nor lower end sound. The meter just turned over 353k. The only part changed internally on the engine was the timing chain at 175k. I suppose the point I'm making is, it really doesn't matter (at least in my opinion) what weight oil you use, as long as it's a good oil.
