Hi All
The car has had its first 2 years of oil changes done at toyota(free)
Those nuts at toyota tightened the filter so hard that i had to use a breaker bar. Btw, my 6" 3/8 extension twisted/deformed when taking it off!
Along with the filter element, I changed only the big o ring gasket this time, put the filter back on and torqued it to 19ft pds(called for 25nM)
There is an apparent leak as the oil filter housing is coated in oil. This is the first leak from an oil filter in my 8 years of maintaining cars.
Anyone have any advice on what could be leaking or wrong? I think those nuts tightened it so tight that the housing thread may not be sealing well anymore. Hope i dont have to buy a new oil filter housing.
