Originally Posted By: JetStar
Definitely some movement. That would be a good place to start. It looks like the spring seats in the lower arm? Is there a jack under the lower arm? I ask to determine if it's fully un-loaded. It might clunk if you get it un-loaded.
I don't know what year your F150 is, but the Mustang 4.6L (3V) had two piece plugs that can come apart upon removal up through some time in late 2008. Do the 4.6's in the trucks have this issue as well?
No jack, it was fully unloaded.
Originally Posted By: bdcardinal
The front dampers on the 04-14 F150s is a coilover strut type setup. Any play past .8mm when unloaded is grounds for replacement per the book.
That year truck should have a 4.6L 2V which does not have the plugs that break in the head.
Okay, Ill go with the upper balljoints being bad, with this one worse than the other side.
And yeah, Romeo 4.6L 2V is whats in it. I happen to have a spare one sitting from my '04 CV in case it blows too.
