4L60E add filter/cooler/temp gauge
by dogememe
01/22/18 11:37 PM
Watching Netflix on Vizio E470VL..
by daves66nova
01/22/18 11:10 PM
Michelin tires wore out rapidly
by llmercll
01/22/18 11:09 PM
Seafoam Rebate Starts Feb. 1
by John_K
01/22/18 10:30 PM
2017 Sentra SR Turbo Oil Recommendation
by Braymur
01/22/18 10:29 PM
Notchy steering and greasing Moog tie rods
by mclasser
01/22/18 10:17 PM
Strength rating of stainless steel/galvanized bolt
by motor_oil_madman
01/22/18 10:06 PM
Rush officially calls it quits
by Jimmy9190
01/22/18 08:41 PM
Oil recommendation for 2003 Mazda B2300 (Ranger)
by ryan2022
01/22/18 08:09 PM
Autozone Castrol ATF on sale 2 for $10 until 2/8
by slacktide_bitog
01/22/18 08:04 PM
Mobil 1 Extended Performance oil filter in Canada
by Snagglefoot
01/22/18 07:45 PM
dual auto oil filters for transmission
by Oldtom
01/22/18 07:44 PM
Kitchen sink basket assembly recommendations?
by MONKEYMAN
01/22/18 07:05 PM
Old Girlfriend
by KeithS_NW_Ohio
01/22/18 06:52 PM
Bob Lutz rumblings
by MaximaGuy
01/22/18 06:45 PM
Valvoline's "Anti-Glug" Technology
by Nickdfresh
01/22/18 05:52 PM
WORRIED: CT scan Dangers
by SumpChump
01/22/18 05:02 PM
07 Honda Fit Sport (L15A) Mobil 1 AFE 0W/20 15,062
by albertdi
01/22/18 04:52 PM
Lubing your Ratchets?
by maverickfhs
01/22/18 04:41 PM
Stuff floating in oil additive...
by 351mustang65
01/22/18 04:40 PM
mnmax, jimkaniki, Poee, picture09, Kat
63995 Registered Users
23 registered (Black, bbhero, Crispysea, digitalSniperX1, 1998CamryCE, Deltona_Dave, 3 invisible), 828 Guests and 12 Spiders online.
63995 Members
65 Forums
277086 Topics
Page 1 of 2 1 2 >
#4005197 - 02/09/16 05:23 PM Heavy-duty combustion chamber cleaner
TexasTea Offline
Loc: Texas
Hi all,
My truck is suffering from pre-ignition spark knock. I am in need of a heavy duty combustion chamber cleaner.
Just last weekend I wanted to clean my combustion chamber, i intended to buy seafoam but they were sold out so i used B12 Chemtool instead (i actually i think i like this stuff better).
I ran the chemtool thru a vacuum hose to the intake (not the brake booster it was actually a piece of vacuum hose i hooked up to the PCV inlet on the manifold since the hose on my 04 silverado 1500 is plastic i had to remove it and use my own, if that matters)
It was a little bit colder than usual night here in Houston TX, and several hours after doing the cleaning i went and took it for a spin and the spark knock was practically non-existent. 90-95% better. immediatley.
Today, while entering the freeway on-ramp i ran WOT trying to see if there was any spark knock happening and it did come back although this time it was a less "harsh" sounding ping (not so much "TICK TICK TICK" as it was "tshh tshh tshh" sounding) about 50% less harsh sounding than usual.
I know for 100% certainty that carbon in the combustion chamber has artifically raised the compression ratio in my engine causing the spark knock.
That being said, my dad seems to think the spark knock is caused due to "cheap gas" which I do use often, but im still expecting 87 octane which is prescribed for my truck, not to spark knock in the winter, even if its from a "generic" gas station such as "Murphy USA" (walmart)
Long story short: I'm wondering if anyone can reccomend a heavy duty combustion chamber cleaner, perhaps one that takes 30-60 minutes to complete, something I can rig up a system to feed the intake with while leaving the truck at idle so i dont have to worry about it stalling.
Also, i know a lot of people recommend filling up the intake with some solvent then killing/stalling the engine to let the solvent sit and clean or break up the deposits, and while i agree that is probably the best way to do it, i am actually too afraid of hydro-lock to do this, so i'd rather spend the extra money and do 2-3 treatments the way mentioned above rather than risk damaging the engine due to hydrolock.
I am considering the MOPAR and/or GM Combustion chamber cleaners, but I am open to any and all suggestions, and also I am interested in hearing anyones experiences chasing after spark knock and hopefully ridding themselves of it due to carbonization in the combustion chamber.
edit: i am also interested in both aerosol and liquid forms, however liquid would be most preferential. if i could rig up a system like the BG cleaner, i'd simply go get a can of BG44k (does anyone know how i can rig up something DIY to use this cleaner with? it seems perfect because it takes 30-60 minutes to actually complete the cleaning process and i need something that runs long and hard to get rid of 150,000 miles worth of PCV blow-by and carbon deposits)
Edited by TexasTea (02/09/16 05:27 PM)
#4005202 - 02/09/16 05:29 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
demarpaint Offline
Loc: NY
Hot water fed slowly through a vacuum line works very well at removing carbon. We've discussed it here a lot, or Google water to remove carbon in an engine for more info and how to videos. Just be careful not to hydro-lock the engine.
God Bless Our Troops
#4005230 - 02/09/16 06:14 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
Ramblejam Offline
Loc: Kentucky
#4005234 - 02/09/16 06:18 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
anonobomber Offline
Loc: WA
Mopar combustion chamber cleaner has worked really well for me in the past and is about $10 for a can.
#4005259 - 02/09/16 06:46 PM Re: Heavy-duty combustion chamber cleaner [Re: demarpaint]
Branson304 Offline
Loc: North America
He is right. Water works well, there are videos around the internet.
#4005270 - 02/09/16 07:03 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
dblshock Offline
Loc: WI.
Run 128oz. of TCW-3 in your fuel 640:1
16 Civic Coupe Touring
640:1 TCW-3 E091
Edge 0/40/XG7317
Firehawk Indy 500
06 4Runner SR5 135k
640:1 TCW-3
M1 0/40 XG3614
Falken Wildpeak AT3W
#4005309 - 02/09/16 07:26 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
chad8 Offline
Loc: michigan
This is the best stuff you can buy. You can not hydro lock foam if done right.
http://www.amazon.com/Johnson-Evinrude-Engine-Tune-Up-777185/dp/B001KYJAL0
When you are done , buy an OEM set of spark plugs and wires for that motor. NOT replacement [censored] .
Knock will go bye bye.
#4005362 - 02/09/16 08:05 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
KingCake Offline
water
#4005371 - 02/09/16 08:11 PM Re: Heavy-duty combustion chamber cleaner [Re: demarpaint]
KingCake Offline
In WWII many of the turbo/supercharged fighter engines, like in the P-38, had water injection systems. Safe, effective, cheap.
#4005402 - 02/09/16 08:32 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
oemjunk Offline
Loc: New york
Could be knock sensors going bad, but just not bad enough to throw a code. I would try better fuel first before testing or bypassing them however.
2000 Chevy Stepside - Secret Recipe
1973 Buick Boattail - M1 10W-30
2006 Poulan Pro 42" - M1 5W-30
#4005877 - 02/10/16 09:58 AM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
TexasTea Offline
Loc: Texas
Thank you for all the suggestions I am actually impressed by the amount of products available suggested here, many thanks.
Some bg on the spark knock:
I just replaced the knock sensors, intake gasket, harness, AND plugs + wires about 1 and 2 years ago respectively. I wish i had done this comb. chamber cleaner before all that, i dont want to mess up my new spark plugs these are "supposed" to last the rest of the life of this truck... ;_;
#4006074 - 02/10/16 01:37 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
SteveSRT8 Offline
Loc: Sunny Florida
We run a fleet of GM 5.3's and 6.0's. Carbon knocking is a familiar complaint here. 2 cups of Kreen in the gas tank removes every trace of it FAST...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#4007927 - 02/12/16 10:16 AM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
ironman_gq Offline
Loc: MN
https://www.youtube.com/watch?v=izvz18xgfA0
Watch this and find a sprayer line the one he's using. Disconnect the intake tube from the throttle body and get the rpm's up to 2000-2500 and start spraying.
#4009079 - 02/13/16 10:16 AM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
CT8 Offline
Loc: Idaho
Water.Then there is the well tested Italian tune up.
#4095187 - 05/12/16 07:51 PM Re: Heavy-duty combustion chamber cleaner [Re: TexasTea]
DallasTexas Offline
Loc: Texas
I have used Kreen on my Diesel Benz with almost 300k miles and it cleaned up 19 years of sludge, freed up rings and felt like the car I purchased it 18 years ago.
Put it in the crankcase and drive 500 miles, drain and change oil/filter. It has money back guarantee.
06 E320 CDI 98k miles
14 Sienna 33k miles
96 E300 297k miles Donated
Page 1 of 2 1 2 >
