Originally Posted By: Falcon_LS
Originally Posted By: Kruse
I remember these when I worked at the dealer. Usually, it takes about a day for some tech to replace these, if the tech is just coasting along.
I'm usually not in favor of government interfering with big business, but if there was a mandated lifetime warranty on a part like this, I guarantee it would be a five minute fix.
Coming from someone who has tackled this as well, I couldn't agree more. This is one the jobs I hate, hate and HATE on these cars - right up there with leaking valve cover gaskets.
I don't think its that bad. Like roadking said it doesn't have to come completely out to do it. I only had to pull the dash in the '10 I worked on because I had to pull the whole HVAC box out and replace it.
There are instructions floating around for doing it by going in through the passenger airbag opening, but Ive done that trick too and it took me longer and was harder than If I had just popped the steering shaft and pulled the dash off enough to get at it.
The driver side valve cover isn't too bad either. Its the passenger side that will make you hate it.
