Hi;
I've been using Mobil 1 'Synthetic ATF Multi-Vehicle Formula' in my Toyota Power steering for years (The manual/reservoir cap specifies to use Dexron III).
It came in a silver bottle and on the label says 'Recommended for use in any power steering unit where a DEXRON or MERCON fluid is recommended'.
I just got a new bottle and it now comes in a gray bottle, labeled 'Synthetic ATF Multi-Vehicle Formula' same as before. (Although it no longer says 'Mercon V' on the front label, but still mentions it in the back).
But, the bottle no longer says anything about Power steering use. Neither does their website Produce data sheet.
I've noticed that it smells different (worse) as well.
I was wondering if they changed the formula and is no longer suitable for Power steering use (as a Dexron III replacement). It seems a little scary that they removed an endorsed use from their literature.
Anyone know for sure?
Thanks;
Thanks;
