I hooked up my OBD-II scanner partly out of boredom after not using it for over a year.
The LTFT was +10.x. I was hoping it was just dirty fuel injectors so I put a bottle of Techron in the tank and filled up.
After 35 miles of running errands 50/50 city/highway then the LTFT was +19.
When I rev the engine up to ~2500 rpm in neutral the STFT swings negative and LTFT drops to single digits.
I replaced the intake manifold gasket with updated orange silicone type 19 months and 13k miles ago.
I was careful to clean the gasket surfaces when I installed the new gasket, but I vaguely remember it being folded up when it came in the mail.
I also replaced the throttle body gasket at that time.
I didn't check fuel trims before or after changing the gasket.
So it might have had this issue from the day I changed the gasket.
I tried spraying carb cleaner: no effect on idle or fuel trims.
I sprayed around the manifold, throttle body and vacuum hoses.
I pinched off the brake booster and PCV hoses: no change.
Pinching off the hose to the EVAP purge had no effect when the solenoid wasn't active.
STFT dropped ~5 counts when hose pinched with the purge solenoid was clicking.
Cleaned the MAF sensor: no change.
LTFT now back to 10-11 and I'll just live with that as long as there are no codes.
