It began rather suddenly one day when outdoor temps remained in the low 50's F at night. Instead of quickly firing off, it would crank for a few seconds, then start. I also noticed the radiator fan would come on after a cold start, and remain on, even after the engine was turned off. That's never happened before. Very odd.
Then one cold morning, it took about 15min. to lite. The tach rose to about 1100rpm and the cooling fan came on! The coolant temp gauge stayed about 2 ticks below its usual 3 o'clock position, before finally rising to 3.
A bit of research led to the ECT (engine coolant temp) sensor. Evidently it's resistance is high when cold, then drops as temp increases. Mine meas. 530 Ohms when cold. Should have been about 3450 Ohms @ 52°F. So the engine computer thought the car was HOT instead. Didn't open the injectors enough for a cold start + even turned the radiator fan on.
Luck was with me this time, I found a genuine Volvo stamped ECT sensor at Advanced Auto for only $27! It was listed as "Borg-Warner"(?). When replacing it, I discovered a split t-stat gasket, leading to a leak. Also realized it's about time to replace the original coolant hoses.
A new sensor solved the cold start issue and the radiator fan running with a cold engine.
