Originally Posted By: mk7vw
Hello. Just out of curiosity, can you add a few ounces of Redline water wetter inside a 2016 GTI with G12 coolant from the factory? I drive my car through the canyons pretty hard on the weekends so I'm not sure how the cooling system holds up, but my digital gauge reads any where from 194F-205F. Just a few ounces not the entire bottle...
Your temperature gauge would tell you how it's holding up. As long as your thermostat is not wide open and your temperatures are rising out of upper bound control then the water wetter will do no good.
