Originally Posted By: SandCastle
The capacities vary by model, engine, and displacement. I suspect the differences in some cases are not real, just the result of sloppiness in the specs. According to VW.COM the sump capacities for the 2016 models are as follows: Jetta S (1.4T)=4.76 qt, SEL (1.8T)=6.76 qt, GLI SE (2.0T)=6.8 qt, BUT for the CC (2.0T)= 4.4 qt, and Tiguan S (2.0T)=4.8 qt. If your 2.0T holds 6.x quarts, then 10K oil changes could be reasonable, but with 4.x qts, a 5K OCI may be more prudent. Perhaps VW will eventually enlarge the CC's and Tiguan's capacities as well to provide more safety margin for the 10K OCI.
To make things more confusing, the Golf/GTI, which their 1.8T and 2.0T have different engine codes than the Jetta/GLI 1.8T & 2.0T, have 6.97 qt sumps. Also with 6.97 qts is the Golf R motor.
Jetta/Passat 1.8T = CPKA & CPRA
GLI = CPPA & CPLA
Golf 1.8T = CXBB & CNSA & CNSB
GTI = CXCA & CXCB
Golf R = CYFB
GLI = CPPA & CPLA
GTI = CXCA & CXCB
Golf R = CYFB
