The taurus now has the "low brake fluid" warning on the instrument panel. I looked the the fluid level, there was still fluid in the reservoir, while it didn't look to be dangerously low, it wasn't at the highest level too. So if I top it off, will the warning go away and what caused the brake fluid to leave the system?
Does using ABS and ESC waste brake fluid? I drove through the snowstorm (but just for a short period of time, 20 miles, not terribly long) but my ABS made the grinding noise it does in the snow as well as ESC quite a few times, Did that use all of my brake fluid, or might there be a leak? I didn't notice a leak before and it just started going off yesterday, the day after the snowstrom when the roads have mostly been cleared.
