Previously using Amsoil ACD30 with a Motorgard Bypass filter.Ran out of the Amsoil and thought I would give the Fuchs a run as well as removing the bypass filter.Hence the shorter run.This vehicle calls for a CD rated oil to be changed every 5,000 kms.
15kkm 40kkm 20kkm 40kkm 40kkm
5w30 ACD30 ACD30 ACD30 ACD30
Fe 38 51 34 65 41
Cr 2 1 3 3 3
Cu 3 3 2 3 5
Pb 3 3 2 4 5
Al 3 4 2 3 4
Sn 0 1 5 0 0
Si 7 5 5 7 5
Na 3 1 0 2 2
Zn 936 1273 1252 1319 1302
P 758 1044 1063 1093 1063
Ca 2083 3303 3124 3414 3747
Mg 7 12 14 13 12
Mo 2 14 4 8 2
B 0 15 0 4 1
K 4 1 0 1 0
Nit 10 10 9 9 10
Oxi 17 48 47 42 38
Sul 22 48 48 41 38
St 65 72 57 58 54
Gly 1 4 4 3 3
V40 63.1 70.8 68.9 71.5 92.4
Was very pleased with these results,no oil was added,however level was at the add oil mark.Have put one litre of topup in and will change the oil and filter at 20,000 kms.With the bypass I was topping up one litre every 5,000kms with the toilet roll change.With an expensive oil like Amsoil the economics are not good.See I listened to DNewton.The full name of the oil is Fuchs Titan GT1 Proflex 5w30 C3.
The first run of ACD30 was an old batch hence the high V40 reading from the first 40kkm run.Oil was changed on all 40kkm runs.
Vehicle is a 1999 Navara[Frontier] with TD27 engine.
Fe 38 51 34 65 41
Cr 2 1 3 3 3
Cu 3 3 2 3 5
Pb 3 3 2 4 5
Al 3 4 2 3 4
Sn 0 1 5 0 0
Si 7 5 5 7 5
Na 3 1 0 2 2
Mg 7 12 14 13 12
Mo 2 14 4 8 2
B 0 15 0 4 1
K 4 1 0 1 0
Nit 10 10 9 9 10
Oxi 17 48 47 42 38
Sul 22 48 48 41 38
St 65 72 57 58 54
Gly 1 4 4 3 3
