New Wix filter for Subaru Applications - 23 psi's
The PH9715 is Fram's equivalent to the OEM Subaru 15208AA12A filter (also made by Fram) and has the correct Subaru bypass spec.
On our Subarus I use the PH9715 exclusively, and each of the roughly half-dozen that I've cut open has looked good.
PH9715 - too low filtration:
Designed for use with conventional oil.
For everyday drivers who perform routine maintenance on their vehicle every 3,000-5,000 miles.4 95% filtration efficiency.
