First simple question. I have Comcast with the phone service. I would like to buy my own modem again. The Comcast one is an Arris tg863g/ct. Now I know I can buy that exact one. But I wanted to buy one with more bonded pairs. That is easy to find. However I also need the modem to handle the telephone. Does such a critter exist??
Second part is I'm upgrading my WiFi router. I have tried 4 different models. I am on my second asus rt-ac87. The first one had a broken antenna. So that is why it got exchanged. The thing I do not understand is the original asus router was giving me almost exactly the same wireless speed of 120 Mbps as my wired connection to my desktop when in the same room. Now this second unit is only giving me 93 max on Tim 5gHz band and I believe I have everything set up the same as before. Also with this router I have had it stumble twice after making changes via the web browser. To the point I had to reset the computer and router. Do these points indicate a bad router. Why would I be loosing almost 35Mbps via WiFi with this router especially when all the antennas are good. At least visually. And they do not make a noise when you shake them like my original unit. thanks
Also tried the asus ac68p. Similar issues to current router. Low WiFi speed. Worse issues when making changes. Would have to reboot several times
And the best buy special net gear r7300. It also matched my wired speed. But cost to much for the additional powerlines adapter that did not work well in my home.
I'm so confused on to what I should expect and get
All routers where set to best 40 on 2,4 and 80 on 5ghz and disabled any b/g protection or legacy supports. To maximize signal and speed on the n and ac networks
