I have converted my stock fuel system to an aftermarket one. The stock gas tank has been replaced by a fuel cell packed with anti-slosh foam and the cell is made out of plastic. The fuel lines are a rubber lined stainless steel braided line. The fuel pump is also an aftermarket unit that can cover the twin turbos thirst.My questions are as follows. Will pump gas cause any problems with the cell foam, the cell itself or the fuel line material over time with the current amount of gas/alcohol mix? I have run E85 before when the fuel system was stock but now can I run E85 again without worry? One last question. Can I use your products and other's like fuel system cleaners without worry. All this comes about from the fact that race fuel cells are made to work with race gas and over a short season not in a daily driver.
