Originally Posted By: wemay
Let's take the example you used... M1 0w40 8.8% Noack. I guarantee you there will be people here that consider pyb 10w30 a 'better' oil because of it's lower Noack.
The difference between that 8.8% and the 4.4% is significantly less than the difference between either of those numbers and oils pushing up on the 15% limit however.
There's a point of diminishing returns here.
I also SPECIFICALLY noted oils carrying the same specifications for just this reason. There aren't any specs that M1 0w-40 and PYB 10w-30 both carry.
However, to entertain this, we are comparing oils with a wide spread (0w-40) to a narrow spread (10w-30) so I would generally expect the oil with the narrow spread to be less volatile. That's a compromise when chasing the 0w-xx rating vs the "Arizona" rating
No, i understand that. I was using the extreme only as a point of emphasis.
But lets take the point of diminishing returns, for instance. How many dicussions have gone 6-7 pages where no matter what the original topic was, Noack between two oils, where the difference may have been slight (~6% vs ~9%), ended up taking a larger percentage of the thread? Forgive my rambling.
