Originally Posted By: goodtimes
I don't like the fiber end cap has "nubs" to center the element though. I'm sure it works fine, but I just want more solid positioning of the ADBV when it is so close to the inlet holes. On some Fram versions like the 3614 the inlet holes are right next to the ADBV sealing surface, so positioning is more important.
I would think the nubs on the end caps would ensure everything is lined up properly inside the can.
