I suppose it depends what you have and what you're willing to use. Your MaxLife is dexos1. Your Defy isn't, but that may change, since that's going SN/GF-5. If someone is determined enough to avoid dexos1, it can be done. Conventional is the easiest answer. An HDEO or A3/B3 A3/B4 lube will also do it. Formula Shell Synthetic and Eneos, off the top of my head, are also non-dexos.
Besides, oil companies are amortizing the tiny licensing fees over all grades. I don't see any discounts for Syntec or M1 varieties that aren't dexos1 rated. Perhaps other oil companies are doing it differently, but I doubt it.
