Originally Posted By: andyd
80 90 is fine as long as it has an open diff.
I hate to reveal my ignorance , but what is an open diff ? As opposed to what other kind of diff ?
This car was my late Dad's car . it has been in storage 15 - 20 years . I am guessing the seal just dried out & got hard . The car has 46,000 original / honest miles . Nothing is worn out .
Follow up - Just finished with the pinion seal on the Caprice & got out of the shower . I was a dirty puppy .
I was running out of daylight . :-(
Put most of a " bottle " of 80w-90 oil in the diff , until it started running out of the fill hole . Replaced the plug and tightened it up .
Had my Wife drive the Caprice slowly around the block . While she was doing that , I spread cat litter on all the oil spots on the drive .
Will have to wait to see if it leaks or not .
The seal surface of the yoke has 2 " wear rings " . I used 500 grit sand paper on it , then switched to 1000 grit . I could still lightly see the 2 " wear rings " , but could not feel them when I drug my finger nail across them .
Lubed everything as I reassembled the parts in reverse order .
I had hoped to do this this last weekend . But this last weekend was not good . Worked on plumbing / cold water lines under the house . 3 steps forward & 2 steps back . Ended up creating a leak , where it was not leaking . Praise the Lord ! . It was no longer leaking by the time I crawled out from under the house Sunday PM .
God bless
Wyr
