G Garak Joined Dec 5, 2009 Messages 28,049 Location Regina, Saskatchewan, Canada Aug 13, 2015 #41 I wouldn't mind if Denso stuff (as in Denso aftermarket) were more readily available here.
E edwardh1 Joined Jan 17, 2003 Messages 3,462 Location Coastal South Carolina Aug 16, 2015 #42 true no one seems to sell dense at least not the common retailers. have to go online
G Garak Joined Dec 5, 2009 Messages 28,049 Location Regina, Saskatchewan, Canada Aug 16, 2015 #43 And here, the online retailers that sell Denso are pretty rare (and expensive) in comparison to the USA.
UG_Passat Joined May 27, 2008 Messages 6,138 Location Parts Unknown Aug 16, 2015 #44 iirc, Toyota air filters are multi-layered, I think 3 different layers from coarse to a fine filter. Mann, isn't, unless you get the cold weather filter if it is available, then it would have a layer of foam glued to the bottom.
