ATP AT-205 How does it work?
by FlyPenFly
6 minutes 48 seconds ago
Valvoline Full synthetic
by S2K
19 minutes 32 seconds ago
Jetta brake fluid swap
by rtrdad
26 minutes 36 seconds ago
Relaxing music = increased livestock production?
by Ed_Flecko
49 minutes 10 seconds ago
Amazing repairs
by SteveSRT8
Today at 12:01 PM
Unknown 0W/20 - 2015 Tahoe 5.3L - 6,467 mi
by E39LSMO
Today at 11:49 AM
GM is running their dexos licensing program in-house
by slacktide_bitog
Today at 11:29 AM
YES OR NO? PUP Dexos 1 Gen 2?
by jcartwright99
Today at 11:24 AM
Norton ConnectSafe being shutdown
by OVERKILL
Today at 10:24 AM
Aretha Franklin has passed away
by Char Baby
Today at 09:43 AM
PennzPlat 0W-20 mix/5890 mi./2017 Pentastar 3.6L
by doyall
Today at 08:57 AM
Ebay $5 off coupon no minimum some restrictions, ends 8/22
by BigD1
Today at 08:47 AM
Sainz to McLaren
by Brad_C
Today at 08:24 AM
5.4 3V Ford Triton Oil/carbon layer at spark plug
by tryamu
Today at 07:12 AM
Estimate on new porch (composite) - Thoughts?
by xBa380
Today at 06:46 AM
Valvoline Advanced Synthetic D1G2/5w30, 6,087MI, 09 Saturn
by smithph
Today at 06:45 AM
Automotive paint?
by Hemispheres
Today at 06:13 AM
I learned something new (historic info)!
by RyanY
Today at 05:46 AM
2015 Accord CVT Filter Change
by Stucker21trt
Today at 02:35 AM
Out, M1 0w-40, In PP 10w-30. Quiet
by wrcsixeight
Today at 01:39 AM
gtg, bsk, heyjobe, RockerSwitches, Jmoney7269
65724 Registered Users
83 registered (14Accent, 2015_PSD, 97f150, 2010Civic, Aero540T, 28oz, 10 invisible), 1728 Guests and 33 Spiders online.
65724 Members
67 Forums
288806 Topics
#3822141 - 08/15/15 12:12 AM Cat T0-2 trans fluid alternative
Catmandude Offline
Loc: NEPA
Is there a comparable oil available that is the same as Caterpillar's T0-2. I believe this oil is an AW30 but with ? additives. This oil is obsolete to the new T0-4 fluid, which I can't see taking out a second mortgage just to fill a '87 D4H Cat dozer's transmission with. Also, the T0-4 is not recommended in the older machines.
#3822147 - 08/15/15 12:21 AM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
camarokiller Offline
Loc: south of pittsburgh
What about napas 303 universal tractor and hydraulic oil?
UMWA local 1702
1993 del sol SI 1.6L napa himi/napa gold
1995 ram 2500 5.9CTD RT6/fram ultra
2015 escape 1.6 eco boost M1 AFE/napa plat
#3822160 - 08/15/15 12:42 AM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
KD0AXS Offline
Loc: Nowthen, MN
Universal Tractor Fluid. Should be available at most auto parts stores, farm/fleet type stores, or even Walmart. Check the label to make sure it meets Caterpillar T0-2, most of them should.
Just a few examples, there are many more out there:
#3822165 - 08/15/15 12:51 AM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
Also if you have a Rural King up there they have UTF on sale this week for 20$
UMWA local 1702
#3822171 - 08/15/15 01:11 AM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
901Memphis Offline
Loc: Northern Kentucky
What about Amsoil torque drive?
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#3822176 - 08/15/15 01:26 AM Re: Cat T0-2 trans fluid alternative [Re: 901Memphis]
KD0AXS Offline
Loc: Nowthen, MN
Well, he said he didn't want to take out a second mortgage. I'm guessing he really doesn't want to take out a second mortgage and donate plasma to pay for the Amsoil. smile
#3822253 - 08/15/15 06:54 AM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
Rob_Roy Offline
Loc: Northern, NY
Do not use the products recommended above, they are not the correct viscosity. Your transmission calls for 30w.
Shell Rotella T1 30w meets Cat T0-2, as does many other SAE 30 engine oils. With that said, who told you the T0-4 fluids are not recommended for older machines? It is a superior fluid and backwards compatible. If you have a Shell distributor nearby ask for a price on Spirax S4 CX 30. I believe your transmission should hold about 30 gallons.
We use TO-4 fluids thoughout our late 70's D8K.
2016 Ford Expedition 3.5 Ecoboost
2015 Subaru Legacy 3.6
2014 Subaru Outback 2.5
1999 Ford F350, V10
#3822574 - 08/15/15 01:53 PM Re: Cat T0-2 trans fluid alternative [Re: Catmandude]
CT8 Offline
Loc: Idaho
A tran$mi$$ion on a Cat i$n't where you want to $crimp on the quality of the oil you u$e.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4305578 - 01/17/17 09:27 PM Re: Cat T0-2 trans fluid alternative [Re: CT8]
earthmover1980 Offline
Loc: SW Michigan
Be very careful with "universal" tractor fluid.
Some of these Cat powershift transmissions call for oil with friction modifier. You don't have to run genuine cat oil, just make sure you use an EQUIVALENT!
#4305708 - 01/18/17 12:32 AM Re: Cat T0-2 trans fluid alternative [Re: Rob_Roy]
zeng Offline
Loc: Malaysia
This.
