Worn cam lobe symptoms
by NICAT
04/23/18 02:19 AM
White car..has white grease
by Vdubuk
04/23/18 02:17 AM
Do you need to change oil if your engine leaks
by Vdubuk
04/23/18 01:35 AM
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
04/22/18 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
04/22/18 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
04/22/18 09:12 PM
DexOS in a 2005 Cavalier LS?
by GMWeber
04/22/18 09:10 PM
US-Canada mail transit questions..
by earlyre
04/22/18 09:10 PM
hybrid ICE wear
by tigrpal
04/22/18 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
04/22/18 08:47 PM
Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
16 registered (Duke, FowVay, edyvw, Billbert, csandste, BlueOvalFitter, 2 invisible), 645 Guests and 51 Spiders online.
64820 Members
68 Forums
282164 Topics
Page 1 of 2 1 2 >
#3821129 - 08/13/15 09:36 PM SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L
jetman Offline
Loc: TX
I do extended oil changes and used oil analysis so we might all learn something and I find it interesting.
This is the 7th UOA I've done on this vehicle.
This analysis is about WalMart Super Tech 5-30w full synthetic . The oil is 8 mths old, w/10,000 miles. The vehicle is a 07 Toyota FJ Cruiser w/a gasoline 4.0L engine that has 142k miles since new. I didn't dump/change anything when I took this sample. I always wait to see the UOA results. No make-up oil was added, because it doesn't use any. The vehicle is my daily driver. We live in the country, so it doesn't see much stop and go driving.
Many yrs ago I put a TopDog brand engine oil bypass filtration system on that utilizes the Amsoil EaBP90 filter. This filter was last changed at the start of this oil run. The air filter is an Amsoil EaA238(discontinued) element with 57k miles since new. I blew it out again at the start of this run Over the yrs, I've looked for induction system leaks and tried 3 different brand air filters elements in hope of reducing the Si/silicon level, all without success.
As I suspected SuperTechs additive package was used up after only 10k miles(low TBN). All the previous UOA I've done was on Amsoil oils. Amsoil additive package is more robust so it last longer, roughly 15k miles. I personally don't like a TBN# below 2.0
After looking over the following results I changed the oil to Mobil1 5-30w? I'll see how it holds up. Will it holdup as well as Amsoil? Will it holdup longer than ST? I changed the full flow filter with another Fram XG8A. I left the Amsoil EaBP90 bypass filter element in place for another run.
LAB: Oil Analyzers Inc - OAI(Polaris)
LAB COMMENTS: TBN # is below acceptable levels. Abrasives (silicon/dirt) is at a MINOR LEVEL. Change oil and oil filter.
Code:
WEAR METALS-PPM
Iron        28....14....12....7....21...17....19
Chromium    0......0....0.....0....0....0.....0
Copper      1......1....1.....0....1....0.....1
Tin         0......1....0.....0....0....0......0
Lead        0......0....0.....0....0....0.....0
Chrom       0......0....0.....0....0....0.....0
Nickel      0......0....0.....0....0....0.....0
Alum        5......6....7.....1....3....2....0
Silver      0......0....0.....0....0....0.....0
Cadmium     0......0....0.....0....0....0.....0
Vanadium    0......0....0.....1....0....0....0
CONTAMINANT METALS-PPM
Silicon     56.....70....43...32...33...37...38
Sodium      168....45....17...28...29...31...29
Potassium   4......2.....2....4....3....5....1
MULTI SOURCE METALS
Manganese   0......0....0....0.....0....0....0
Titan       0......0....0....0.....0....0....0
Molybdenum  2......0....0....0.....0....0....32
Antim       0......0....0....0.....0....0....1
Lithium     0......0....0....0.....0....0----1
Boron       6......4....3....1.....1....2....1
ADDITIVE METALS-PPM
Magnesium  14.....11....16....10....13....11....12
Calcium    3394..3531..4351..3589..3022..3520..2417
Barium     0......0......0.....0.....0....0.....0
Phosph     568...497....809...929...895..1037...643
Zinc       691...591....989..1130..1084..1236...757
V100C         10.9...10.8...12.7....14.3...15.2..12.7...10.2
I-R Oxidation 58......64.....61......25....67....50....27
I-R Nitra     39......41.....17.......9....18....18....15
TBN         2.66...2.18...2.48....2.35...1.89...2.22....1.43
Fuel         <1%......<1%...1.0-GC%..<1%....<1%...<1%...<1%
Soot Vol     <.1%....<.1%...<.1%....<.1%...<.1%..<.1%
Water Vol    <.1%....<.1%...<.1%....<.1%...<.1%..<.1%..<.1%
#3821137 - 08/13/15 09:41 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
CT8 Offline
Loc: Idaho
Artificial intelligence is no match for natural stupidity, we shall prevail
#3823498 - 08/16/15 12:59 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
garyb80 Offline
Loc: South Texas
That was interesting. Thanks for posting. I have the same 1GR-FE engine as you and was wondering how SuperTech Synthetic would do. I also use 10,000 mile OCI because it's easy to just reset the oil change light once at 5000 and change it the next time around. Looks like you got every bit of use you could safely get out of that oil.
One question though. I'm assuming the ST results is the column on the right. Is that correct?
#3828364 - 08/20/15 06:43 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: garyb80]
jetman Offline
Loc: TX
Yes the ST is on the right.
Oldest on left, to newest on right
#3828379 - 08/20/15 07:03 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
Al Offline
Loc: Elizabethtown, Pa
I would try Blackstone. I am not believing the numbers for Ca., Boron and Sodium.
http://www.pqiamerica.com/March2013PCMO/supertech.htm
#3830415 - 08/22/15 08:54 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: Al]
Colt45ws Offline
Loc: Central Washington
I would trust it over 2 1/2 year old data.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#3895684 - 10/24/15 09:25 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Oil looks good for a "budget" syn, no excessive viscosity thickening(as seen in some amsoil UAOA), reasonable OXIDATION# ..
But,
Where the Boron in the analysis? STS uses no moly and a load of boron?
Edited by ARCOgraphite (10/24/15 09:27 AM)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#3895951 - 10/24/15 03:29 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
Greasymechtech Offline
Loc: Paradise of Florida
Supertech has different blenders, like a box of chocolates, you never know what you're gonna get.
Supertech full synth should be fine for any OE recommended interval. This UOA isn't bad but expected more with the larger oil capacity(XG8a + EABP90).
I'd want to go 15k, 20k, or more with a bypass setup. TBN just isn't there with supertech. What are the mileages on the previous runs? How often do you change the EABP?
You need particle counts to see how well that bypass is working.
Air filtration? try a Volant intake with the Donaldson Powercore filter and Volant prefilter.
How dark is oil after the 10k run?
Do you drain the EABP90 after a run?
At what point should a lurker start posting :-)
#3897473 - 10/26/15 08:46 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
Loc: N.H, U.S.A.
AFAIK only WPP blends the synthetic in the USA.
#3897798 - 10/26/15 02:12 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
meborder Offline
Loc: SD - South Dakota
Thank you for posting up the second most interesting UOA I've seen on this site.
Second only to the one with 30k and microgreen filters.
Too many cars using too many different oils to list in 150 characters.
#3898506 - 10/27/15 08:42 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
Supertech is blended by Mobil, Citgo, Warren, and whoever is a lowest bidder for the area of a contract. Just verify the bottle to see the supplier.
#3899997 - 10/28/15 01:48 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
salv Offline
Loc: Cadyville, NY
This is the Citgo variety of ST. Good oil.
2003 Trailblazer: Mobil Super HM 5w30 L25288
2000 Ford Focus Wagon: Mobil Super 5000 DW-5230
#4276694 - 12/16/16 06:43 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
veryHeavy Offline
Loc: MN, CA
Go back to the stock air filter.... but go with a quality brand (not Toyota). Your silicon levels will drop dramatically, because paper filters stop dirt better than oiled foam
#4276746 - 12/16/16 07:45 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: veryHeavy]
FlyNavyP3 Offline
Loc: Jacksonville, FL
I've always had exceptionally low Si levels with OE Toyota air filters. Not sure what the basis for not recommending a Toyota OE filter here is.
Luke
#4278757 - 12/18/16 09:33 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: ARCOgraphite]
dave1251 Offline
Loc: Maricopa, AZ
I would like to see the reasoning why people believe there is multiple suppliers for Super Tech. I can only find one API license for Super Tech.
don't use.
Page 1 of 2 1 2 >
