I noticed recently that this blower wasn't putting out near the CFM it used to. At times, the fan speed would increase, but then decrease. As the sled is now in her "mature years", I figured the blower motor bushings needed a lube.
Extracting it was straight forward. The squirrel cage blower fits on the splined shaft and you'll need a 3-prong puller to remove it.
The motor would spin, but not easily, and it would no longer coast to a stop, but abruptly stop.
The rear motor cover is easily removed and four tabs hold the oil-wick cap + bushing in place. This was completely dry.
The front motor bushing is inaccessible. I began prying on whatever I could get ahold of, but little joy. Note the brushes are up front instead of the rear. There was A LOT of dark brown/black dust inside and covering the outside of the front. Not sure if this was from the brushes arching or what.
I sprayed in some alcohol brake cleaner to flush it out, then sprayed a bit of DeOxit red into the front when I could see the commutator. I did manage to open up a gap up front, so added some ND sewing machine oil in the crack.
I went to test the motor in the car. No joy. A resistance test between the two motor terminals indicated a short. Not sure how that happened. Perhaps I jarred the rotor out of the brushes and it shorted there?
Looks like I'll be QUICKLY obtaining a new one as it's baking in fajita flats here (104°F).
This motor has been in service since July 1997! 18yrs!! I'd say it's gone the distance as this motor is (very) rarely off here.
