Which of the above brake lines to your prefer? From some researching I have done: the Nickel Copper seems to be the best overall in forming to corrosion resistance, but is the most expensive. Nicopp meets DOT,SAE,ISO specs, but some have a concern of strength compared to steel. According to some real world users, Galvanized steel and Poly Armour have about the same resistance to corrosion , although mfr claims PA is better. PA is be promoted as easy to form, but I don't know if it easier than Galv Steel. Some reports that the PA coating chips off during flaring where held in the flaring clamp. I saw PA in the package where coating was chip off in the package at the parts store. That doesn't give me confidence it will last when installed.
