Originally Posted By: bobbydavro
VW 502 requires all ACEA tests plus the VW T4 test. MB229,5 is no more challenging from a hardware point of view.
MB 229.5 has to pass all the same tests as required for VW 502.00 spec, plus many other tests. According to lubrizol, the 229.5 spec surpasses VW 502.00 spec when it comes to wear, sludge, and piston deposits. Is this not correct?
According to Lubrizol, MB 229.5 even surpasses the A40 spec in some areas. But then again, I'm not sure how they can make an educated apples-to-apples comparison if the tests are performed on different hardware.
