I have a bike with a separate final drive which consits of gears and bearings. There are no clutches. The gears have been changed from 12.1:1 to 8.4:1 ratio, and the bike has been pretty heavily modified. It originaly went 25mph, now it does a little over 70mph.
The factory manual calls for 10w40 motor oil. I am looking at two different oils, and trying to decide if one would be better than the other based on specs. I want to use something better suited for gears than a standard motor oil. Of course I want the best protection, bur at the same time dont want something that is so heavy that it could decrease efficiency. I have found these two oils which look like good candidates. The first oil is labeled as a gearbox oil good for use with wet clutches. The second oil is labeled as a gearbox and differential lubricant.
Oil 1
Density @ 20°C - .874
Vis @ 40°C - 108.8
Vis @ 100°C - 15.4
VI - 149
Flash Point - 230°C
Pour Point - -30°C
Oil 2
Density @ 20°C - .897
Vis @ 40°C - 72.6
Vis @ 100°C - 15.2
VI - 222
Flash Point - 200°C
Pour Point - -60°C
Oil 1
Vis @ 40°C - 108.8
Vis @ 100°C - 15.4
VI - 149
Flash Point - 230°C
Pour Point - -30°C
Oil 2
Vis @ 40°C - 72.6
Vis @ 100°C - 15.2
VI - 222
Flash Point - 200°C
Pour Point - -60°C
