- Joined
- Jul 2, 2007
- Messages
- 5,294
If hoses are not leaking where might I look to next? I can't even trace where it's dripping off from the underside, everything looks dry. It's not overflow coming out the reservoir blow off hose. Mileage is getting up there, about 130,000. Coolant has been fully flushed, once at 67,000 miles and again at 105,000 using the Ford OEM gold stuff both times by a shop with flushing pump machine or whatever they use. 105K flush was not supposed to be done but it was in for the 100K major service and forgot to tell them the coolant had been flushed already at 67.
