For blade sharpening, an oil change or what not, it seems I get a puff of white smoke on the initial startup after after past mowers have been over on its side.
Does oil make its way past the rings? through the valve guides? maybe the breather tube?
I always used to get the puff on an old brigs that is now gone, but Im sure that was from wear. My one season old Toro with the 159cc toro OHV engine just gave off its first puff of startup smoke, which its never done before, but to be fair it wasn't just on its side, I had it nearly upside down for under deck maintenance.
It's had about 4 oil changes of Rotella T5 at this point, and never a lick of smoke before, but the mower never went past resting on its side wheels.
