Hey Everyone, in a slight dilemma over which oil to use for Diesel Kioti Mechron or rebranded Cushman 1600XD.
The manual states for the Transmission Transfer Case (which has hi, low, reverse), the front axle and rear axle it should all use the same oil.
SAE gear oil No. 90 or
DAEDONG: UTF55 ??? Can't buy it in UK
Shell: DONAX-TD
Exxonmobil: Mobilfluid 423 or 424
BP: Tractran UTH
Shell Donax-TD isn't available any more, but the new version is Shell Spirax S4 ATF HDX. But, by looking at that, I can use any SAE 90?
Can someone clarify whether there is a difference between EP90 and EP80w90 ?
I have some of this right now, is it suitable?:
http://www.mobil.com/Russia-English/Lubes/PDS/GLXXENPVLMOMobil_ATF_320.aspx
Which I'm trying to work out whether it is compatible by cross matching it with specs of this:
http://www.cnergyasiapac.com/assets/Uploads/Shell-Spirax-S4-ATF-HDX-en-TDS.pdf
SAE 90 is GL-1 I think? But the above 2x fluids don't have a GL rating of any sorts?
Any ideas?
My thoughts might be, I'm supposed to use an SAE 90 Gear oil for the front and rear axles. And the Shell Spirax S4 ATF HDX for the transmission and transfer case.
Shell: DONAX-TD
BP: Tractran UTH
Any ideas?
