Forgive me if this has been asked before, and I'm sure it probably has.
My owners manual specs my oil as 5W-30, and I often read of BITOG members who opt for a 40 or 50 grade at the upper end of the scale.
How do you know if you might want to consider a thicker oil, like a 40 or 50, and under what conditions might you even consider it? Or, should you always stick with what your motor is designed to run?
Ed
Ed
