Hi everyone,
I am new here. Have some questions about my fav old friend. I bought this jeep in Oct last year. 168,000 odo. Ran fine. Around end of Nov, I changed oil to 5w 10 synthetic Mobil. Shortly after I hear big tapping noises when I start in morning ( later I was informed "lifters"). Then it became worse and started backfiring through intake ( carburetor) and exhaust sometimes and started missing idling and feels like not getting fuel. Not driveable, unless I give clutch too with gas.After new synthetic oil, oil pressure is bet 10 to 15 on the gauge.
Bad winter here and I have another car so never drove it till now. Meanwhile, I have a friend who is handy and we changed one by one many things: ignition coil, Module, fuel pump ( situated on the lt side of motor), EGR valve( which had a busted diaphragm). After all these, Slightly better with misfiring and backfiring, but still not driveable. Spark plugs become dark in a few minutes or hours if we kept on or drive around a bit.
A mechanic came to look and he thinks it is ignition related: one cylinder is misfiring,...
I have to take it his shop.
Looks like I need to take motor to rebuild or a swap.
Now the question:
Just before I do swap engine or something.. the mechanic suggested 5w30 synthetic is not the proper oil for this old engine.He is telling me I am losing compression and plenty of blow by. He said try some heavy oil:
I am not good at these. Please give some good suggestions: I have heard people using Rotella 15 w 40 diesel oil on these old engines with good results.
1) Which is more thick or viscous: Rotella 15 w 40 or Quaker state conventional 20 w 50?
2)In other words, Does diesel engine oil has more viscosity than petrol engine oils only at same viscosity index?
OR
a diesel oil with 15 w 40 viscosity index is less thick than a conventional oil with a higher viscosity index of 20 w 50
3) Does anyone think by using a HEAVIER oil I could be fix lack of compression in one or 2 cylinders? ( which I have to take to a mechanic this week for compression test and check timing with a timing light as my friend do not have one)
4) Since oil pressure is 10-15 . Ideally around 40 if I am correct. How do I know if the oil pump itself is bad. Is there any way to test it? Or by using a heavier oil, oil pressure should arise?
Any advise about oil thickness or about Jeep misfiring will be greatly helpful. Just want to try everything before I spent $$ for rebuild or swap.
Thanks
Joseph
Now the question:
OR
Thanks
Joseph
