Originally Posted By: jk_636
Futuredoc a quick search will show you just as many filters without tears. Give it a rest.
Yes, but those photos were taken with cameras that used film... or were painted on caves.
Even if we were seeing 5:1- good:torn it would still be way to many failures. Right now it looks like the opposite with most reported filters coming back torn than in good shape (we might be at 1:1 best case scenario). In my case, Purolator went ZERO for two. Statistically, you should NEVER have back-to-back failures.
Right now, the filter being reported are mostly 2014 stock as the supply-chain/usage window should be coming close to getting 2015 filters on the self... and it will take some time for folks to log the miles in order to change and cut.
