I recently picked up a 2006 Jeep Grand Cherokee HEMI with 90k miles which has the 545RFE transmission. I picked up both of the Mopar filters and a Fel-Pro trans pan gasket and now I'm trying to figure out which ATF+4 to go with.
The truck is my daily-driver and this week I'll be installing a 4" lift with 34" tires. I also like to drive onto the beach a lot during the summer.
With that being said...
Valvoline and Castrol are both readily available at my local Autozone etc. and as well as on Amazon. Which would be better out of those two readily available brand ATF+4 fluids?
Now onto the designer fluids such as Redline, RP and Amsoil. I see that some say they surpass the ATF+4 specs but none of them are on the list of certified ATF+4. So are they good enough, or not???
