I have a leak under my (10 y/o) GE dishwasher which appears to be coming from the 'drain solenoid'. It appears to start leaking when the plunger on the solenoid engages (goes down). Before I spend over $40 on a new solenoid I wanted to ask if there is any washer/gasket inside the solenoid that would cause leaking?
This is the solenoid:
http://www.partselect.com/PS260117-GE-WD...um=GSD3800G00WW
Any insights would be appreciated.
